Restoration & Repair Tips Board
How to acced to the oil filter on TE20, 1949 Harry Ferguson
Alan T
10-03-2007 19:04:29
I would like to change the motor oil filter.
The cover filter plate (about 7 inches diameter)have two bolt, a small one on the side and a big one at the center. The center bolt is welded to the cover.
What is the procedure to acced to the filter.
Thanks
Graeme Wardlaw
10-11-2007 16:55:20
 Re: How to acced to the oil filter on TE20, 1949 Harry Fergu in reply to Alan T, 10-03-2007 19:04:29
There should be a bolt going through the housing and down through the filter. The other end of the set up. May be some one has monkey'd with it, then try a filter wrench and rotate the housing.
