Ollie no spark
johng
04-23-2002 19:17:21
it just quit!!?? 65 550 oliver ,, it worked all day then just died now i have no spark to vthe distributor//!?!?!? help???!?!?
Jerry B
04-25-2002 08:26:36
 Re: ollie no spark in reply to johng, 04-23-2002 19:17:21
Check these in the following order:
Primary coil wire.....Connected and getting current to the coil?
Resistor....connected and not burned out?
Coil wire....ends clean and not burned?
Points..Clean and opening?
Condenser....Not much of a way to check execpt to replace it.
Coil...not getting hot and breaking down?
Distributor....rotor turning?
You can use a test light to trace the circuit or a volt meter. I prefer a test light as it requires no great skill. The bulb glows or it don't.
