Automobile Repair Internet Site
DJ (TN)
04-24-2002 15:10:41
Is there an internet site like this that will answer Automobile repair questions?
Thanks! DJ (TN)
Bob Keller
06-06-2005 18:20:52
 Re: Automobile Repair Internet Site in reply to DJ (TN), 04-24-2002 15:10:41
The bolt and wing nut that secures my spare tire in the trunk of my 1998 Chevrolet Cavalier have congealed due to rust. How do I remove the spare tire?
LG
02-24-2005 19:04:41
I have a friend that bought a old 1995 Grandam
that was sitting down for about 2 years, He
put in a used motor that runs good. Trouble is
the gas isn't getting to lines to crank. When
he tries to crank it motor just turns won't crank.
I may not be wording this right Iam a woman seeking help. Thank You!
JIM BARKER
04-18-2004 19:06:26
1993 Ford Escort 1.9
I have been trouble shooting a cooling system problem. Temp guage slowly goes to the max normal range. I have replaced the thermostat, radiator cooling fan switch (fan does come on and cycle),
head gasket, clamps and hoses,flushed entire system, pressure tested for leaks. The only thing I have found out of the ordinary, is the t-stat housing seems to have a plstic valve or something to allow by-pass. with a great deal of effort and patients I slowly but surly was able to chip away what ever is in the housing re-install t-stat and gasket to no avail. Is ther something I am overloooking??? Please advise when possible. Any input would be greatly appreciated.
erroll anderson
10-14-2003 12:31:02
I have a 1996 Dodge status I took it to a mechanic that wasn't a dealer for a problem of the car shutting off. I told him I believed it was an overheat problem. Because I knew that the fan was not operating. He diagnosed the problem and told me I needed head gaskets and a head which he did which was ok because I had been told by others that i may have this problem. However when he returned the car the first couple of times the car still would not run right and it doesnt run right now. The check engine light is now on constantly and it wasnt on before. The transmission is stuck in second which it wasnt before. Between all my complaining and bringing back the car for this and that problem he also repaired an engine seal. My question is this. Could he have caused the check engine light and the trans. stuck in second problem with the work that he did?
Shawn Anderson
09-05-2003 17:39:47
i have a 83 NISSAN DATSUN 4X4 PICKUP WITH THE 720 engine 2.2 liter the problem i have is it wont start with the key or by jumping the starter sol. what do i need to fix or replace
Mark
12-17-2002 20:13:47
Help - Student repairing 87 Dodge Shadow - Put in new struts and now the steering is shot. Very loose and not much control. Any help in advising what I did wrong or how to correct it would be appreciated.
kruse
05-02-2002 13:52:22
Another good site for auto / small engine is: www.batauto.com
Duner Wi
04-25-2002 16:44:27
Take a look at www.allexperts.com
DJ (TN)
04-28-2002 09:37:03
 Re: Re: Automobile Repair Internet Site in reply to Duner Wi, 04-25-2002 16:44:27
Thanks Duner! Just the site I was looking for. Thanks again. DJ (TN)
