Restoration & Repair Tips Board
Stuck Motor
Bill from Scotl
10-17-2007 14:48:06
Hi Guys
I have a stuck V8 Perkins, water in the cylinders and piston rusted in place. I have tried soaking them in WD 40 but still completely stuck . I cannot see any easy way of getting at the underside of the pistons to knock them free + I guess I am going to be fighting against the other 7. I was thinking about welding up a frame, fixing to the engine block with the head bolts and placing a steel plate over the piston head and using a small hydrolic jack to force down one of the pistons. What do you think? I have other pistons and sleeves I can put in once the motor is free.
Thanks for your thoughts.
Bill
old
10-17-2007 17:05:41
 Re: Stuck Motor in reply to Bill from Scotland, 10-17-2007 14:48:06
If its a deisel try turpinetine. If its gas try tranny fluid.
edss!
10-17-2007 15:06:43
Instead of WD try Kroil or another penetrateing type oil
