Restoration & Repair Tips Board
Aluminum Irrigation pipe
Teebogr81
10-18-2007 12:24:50
I've inherited 20 or so joints of irrigation pipe with the small farm I purchased. What is the best way to repair small cracks/splits in the pipe?
Thanks....
JerryCPP(WA)
10-29-2007 13:16:35
 Re: Aluminum Irrigation pipe in reply to Teebogr81, 10-18-2007 12:24:50
You can also use aluminum stick welding sticks with a gas torch. It works just like a flux-coated brass rod for brazing. Just be careful of the heat - aluminum gets to a near-melting point and the next few degrees and it's gone.
glennster
10-22-2007 08:07:15
best way is to mig or tig weld the cracks. there is a welding rod you can get, seen it at big r's farm store to repair aluminum with a torch. must be like brazing. havent tried it but its supposed to work good.
