Restoration & Repair Tips Board
1966 John Deere 3020 Hydraulics
Rick Niemeyer
10-18-2007 13:44:33
I have a 1966 John Deere 3020 and the steering, power brakes and lift does not work. When it was parked, all worked fine. It set for nearly a year, and when I started it up, there was no power steering, brakes or lift. Of course I have checked the fluid, replaced the filter, and cleaned the tube filter. Any ideas::??
Rick
msb
10-18-2007 14:58:00
 Re: 1966 John Deere 3020 Hydraulics in reply to Rick Niemeyer, 10-18-2007 13:44:33
Check the main hydraulic pump drive coupler. It may have sheared the spines inside when you first started the engine.You should be able to see if the pump shaft is turning.
Rick Niemeyer
10-18-2007 16:13:49
 Re: 1966 John Deere 3020 Hydraulics in reply to msb, 10-18-2007 14:58:00
Thanks so much for your reply. I have checked to make sure the pump shaft is turning. I failed to mention that in the original message. Also I have removed the control valve to make sure it was not stuck. I was told if that valve was stuck, I would not get any pressure either. Still looking. Rick
msb
10-18-2007 14:57:54
Rick Niemeyer
10-19-2007 12:31:35
 Re: 1966 John Deere 3020 Hydraulics in reply to msb, 10-18-2007 14:57:54
I have checked the main pump and it is turning. I can see the shaft turning going into the pump.
Thanks again,
Rick
