Restoration & Repair Tips Board
9n no spark
jody pullium
10-28-2007 22:31:47
I am having trouble getting no spark. I am trying to relace the points I have replaced everything else. However I have ordered points from 3 different places. None are the same. I have taken out the metal disc that the points screw to. The points has a metal rivit attaching the points. It looks like a screw that can change the gap. I have filed that rivit off and now the new points screws doesn't line up is there a part that i can order that has the points attached to the metal disc. Please help. Part number and a name of the piece maybe even where i can get one. anything that I can try
old
10-29-2007 07:30:53
 Re: 9n no spark in reply to jody pullium, 10-28-2007 22:31:47
Sounds like your either doing something wrong or some one really screwed up the distubutor at some time. The points should come out by removeing 2 screws and slip right out and then you put them back in the same way. The I-T manual FO4 has a picture of how they should look on page 19. If you don't have the manual I would say gettig one is the first place you should start so you can fix your porblem
soundguy
10-29-2007 07:27:21
Hey!.. wouldn't it have been great to post this in the Ford N forum. by now you'd probably had 35 good answers!
So.. what type of distribuitor do yuo have? Angle mount ( 5 nipple cap ).. or front mount ( 4 nipple cap ).
makes a difference onthe breaker plate and the points.. IE.. 2 different kinds.
Distributor, Breaker Plate - Breaker assy, complete with points. For 2N, 8N, 9N. For front mount distributor. (Part No: 9N12150) $35.51
Distributor, Breaker Plate - Deck plate with points & condensor. For 8N. For side mount distributor. (Part No: FAD12152A) $26.40
Here's the information for the 8N side-mount distributor parts: Side-Mount Distributor: Points:
NAPA #CS749
NAPA HEAVY DUTY PIERCED (ventilated) #CS753
Standard Ignition #FD-8081
Standard Ignition Blue Streak #FD-8081X (Premium) Condensor:
NAPA #FA66
Standard Ignition #FD-75
Standard Ignition Blue Streak #FD75X (Premium) Rotor:
NAPA #FA67
Standard Ignition #FD-108 Distributor Cap:
NAPA #FA352
Standard Ignition #FD-128
Front Mount distributor... Points:
NAPA #CS35
Standard Ignition Blue Streak #FD-6769X (Premium) Condensor:
NAPA #FA200
Standard Ignition #FD-71 Rotor:
NAPA #FA300
Standard Ignition #FD-104 Distributor Cap:
NAPA #FA350
Standard Ignition #FD-126
Soundguy
jody pullium
10-28-2007 22:32:44
sorry I meant 8n
