Restoration & Repair Tips Board
WD starter
tom harris
10-30-2007 09:28:18
thanks for help,WD wont start battery checked fine assuming needs starter? can i get one at auto parts store or is it special??
April
11-16-2007 13:19:51
 Ive got a starter if you need one. in reply to tom harris, 10-30-2007 09:28:18
Hope it turned out that you didn't need a new starter but if you do I have one on the shelf. $185. April 360-426-9299
tom harris
11-16-2007 15:58:45
 Re: Ive got a starter if you need one. in reply to April, 11-16-2007 13:19:51
havent checked into it yet,neighbor machanic is going to look at it,thanks will keep in mind
old
10-30-2007 10:55:58
 Re: WD starter in reply to tom harris, 10-30-2007 09:28:18
As JMS says check and clean all battery connections. Your problem can also be the push buttom switch on the starter also. Common for them to get dirty/burned and not work as they should
tom harris
10-30-2007 11:47:04
 Re: WD starter in reply to old, 10-30-2007 10:55:58
thanks,i know its not the battery connections,maybe button,it has the pull handle start and it is not as easy as use to be
JMS/.MN
10-30-2007 09:53:24
Before getting a new starter, check lyour cable connections, and remove the starter, clean up rust or paint where it mounts in the tractor, that is the ground path. Have the starter checked at a repair shop.
tom harris
10-30-2007 11:49:10
 Re: WD starter in reply to JMS/.MN, 10-30-2007 09:53:24
great will do,thanks
