Restoration & Repair Tips Board
9n ford motor sounds
Young Bull
11-21-2007 14:02:52
If I am going down a moderatly steep grade the motor sounds like popcorn popping/or a rock being thrown around inside the lower part of the motor. Could this be my oil pump is bad? My dad wants me to tell all that the Motor does have enough oil checks it everyday loves his 9n.
msb
11-23-2007 17:13:42
 Re: 9n ford motor sounds in reply to Young Bull, 11-21-2007 14:02:52
Piston slap?
ken in texas
11-23-2007 09:52:05
How about this,pull the starter and check the drive for marks made by flying metal pieces,or missing starter parts.Good luck...
Bob
11-21-2007 14:22:18
Since these engines don't have hydraulic valve lifters, they don't begin clattering loudly as QUICKLY as modern engines do, if oil pressure is lost.
And, once they DO begin to clatter from loss of oil pressure, typically, bearing damage is already done.
How long has it been doing this?
What is the oil pressure while it's making the noise?
Have you ruled out the fan hitting the radiator shroud, or other things of that nature, up front?
Is it possible some junk (spare starter drive parts) is getting slung around inside the bellhousing?
Young Bull
11-21-2007 14:37:56
 Re: 9n ford motor sounds in reply to Bob, 11-21-2007 14:22:18
Thank you so much!! The fan is cleaning fine so it is inside. The oil pressure is at 19 pounds. Something sounds like a sewing machine also. Which I am guessing are the valves that increase and decrease with RPMs. "To be reseated this spring." by dear old dad. The popping / crackling is what I am worried about at this point. Thank you again Bob, please advice as much as you would like.
old
11-21-2007 15:41:08
 Re: 9n ford motor sounds in reply to Young Bull, 11-21-2007 14:37:56
Well if oil pressure hold then its not likely to be the oil pump. But it could be parts of a starter drive as Bob say getting picked up and thrown around by the fly wheel.
Young Bull
11-21-2007 15:53:46
 Re: 9n ford motor sounds in reply to old, 11-21-2007 15:41:08
What would I do to check this?
Mark Pearce
12-02-2007 22:50:45
 Re: 9n ford motor sounds in reply to Young Bull, 11-21-2007 15:53:46
Hand crank anyone?
Take the starter off and crank it the old way, with a hand crank. Then go down your hill see if it does the same thing. Or if it does if it"s louder. Just a thought.
Mark.
old
11-21-2007 19:29:28
Well with out splitting the tractor there is little you can do to check that if it is in fact starter parts
