Restoration & Repair Tips Board
Ferguson te20
Morris McCaslin
11-22-2007 21:01:42
I have a Ferguson te 20 with ohv Cont. indust. engine. After pulling the head because of water in the oil I discovered cracks between all cylinders. The engine runs good the sleeves look fine. Is it fixable, cost, boat anchor? Thanks
Jerry/MT
11-23-2007 10:38:19
 Re: Ferguson te20 in reply to Morris McCaslin, 11-22-2007 21:01:42
This is a vey common ocurance on the Z series Continentals that have been overheated. My TO-30 had the cracks between #2 & #3 cylinder but they never leaked since the engine was modified with tension rods that pulled the cracks closed and the cracks never reached the bottom of the bores. Holes were drilled in the water jacket on both sides of the block and then threaded rods were placed through the holes nuts were added and the rods were tensioned to pull the block sides together. I replaced the engine with the remanufactured one that was furnace brazed and have had no problems with the remanufactured engine.
old
11-23-2007 08:15:57
Very common problem in sleeved engines and most of the time its no big deal. I can't say for sure on that engine but I know in the Allis WD, B,C, WD45 its very common to see them and its a case if they aren't real bad put a new head gasket on and go
