Restoration & Repair Tips Board
5star 3pt hitch
unclefuf
11-28-2007 15:35:10
A friend has a 5star diesel. the 3pt hitch will raise but won't go down. It will however go down with the tractor off for some time, settling that is. where does a guy start to repair this?? thanks jeffuhland@yahoo.com
oliver fan
11-29-2007 13:34:49
 Re: 5star 3pt hitch in reply to unclefuf, 11-28-2007 15:35:10
Lift the seat up. You will then see two leavers about 4 inches long. These leavers turn in a horizonal half circle. One will be a little higher than the other one. Make sure both leavers are pointing toward the front of the tractor.
unclefuf
11-29-2007 16:37:42
 Re: 5star 3pt hitch in reply to oliver fan, 11-29-2007 13:34:49
thanks much, I'll check that out. What if they are not pointing forward???
oliver fan
11-29-2007 20:21:38
 Re: 5star 3pt hitch in reply to unclefuf, 11-29-2007 16:37:42
The leavers are to adjust the action of the 3 point. The lower (right) leaver is to adjust the draft control of the 3 point. The higher (left) leaver adjusts the lowering speed of the 3 point. When it's pointed foward the 3 point drops like a rock. Turning that leaver to the left slows the drop speed of the 3 point. When the leaver is pointed toward the left rear wheel the 3 point won't drop at all.
unclefuf
12-01-2007 14:57:38
 Re: 5star 3pt hitch in reply to oliver fan, 11-29-2007 20:21:38
OK,I finally got to go look at the tractor. The 2 leavers you mention don't seem to have any effect on the hitch operation. The 3pt control lever is in the far down position and is stuck there. It will move a little,[1/2" or so], and does cause hitch to come up alittle, similar to how moving remote levers does without anything plugged in to them.The tractor can be shut off and jiggle levers until the hitch is down to drag the blade,then hit the lever and it jumps right back up. Any more idea's would be greatly appreciated. thanks for your help
unclefuf
12-01-2007 19:37:54
 Re: 5star 3pt hitch in reply to unclefuf, 12-01-2007 14:57:38
The guy said a JD dealer re sealed the rear of the tractor and things worked for a while. I saw the set screw looking thing you mentioned but didn't mess withit. The tractor is 25 miles from me[eastern colo] so I think we'll haul it to my shop and play with it some more. Yes, was using the far outside lever.
oliver fan
12-01-2007 17:07:18
You are using the leaver that is farthest from the seat aren't you? Not the one next to the seat. If so, read my next post.
oliver fan
12-01-2007 16:27:51
I don't really understand why the control leaver is stuck in the down position. The 3 point leaver, that is on the outside (closes to the tire), has two ranges. You need a operators manual to figure out the place to set the leaver for different jobs. An operators manual for a 335, 445, 4 star, 5 star, M-5, or a 602 would tell you hou to adjust the linkages, as they all adjust the same.
One question, has anyone worked on the rear of the tractor lately? Has anyone tightened any bolts around the 3 point top link mount? There is a bolt that looks somewhat like a set screw. That bolt comes up against a small plunger that goes into the hydraulic unit. If that plunger is not free to move, and/or pushed in by that bolt, it will act like you describe.
Where do you live? Do have anyone near by who knows their Molines? I would bet your problem is on the outside and most likely just an adjustment.
