Quick easy way to clean electrial terminals
Ralph Butteris
10-10-2001 06:53:06
Ever have electrial terminals that need to be cleaned/ restored? Get the following items: 1. common every day CLR. 2. Tooth brush 3. WD40 Dip the tooth brush into the CLR and scrub the terminal. Than spray with WD40. You will end up with a terminal that has very good conductivity. THis works on battery terminals, light switches and such.
RayP(MI)
10-10-2001 18:53:29
 Re: quick easy way to clean electrial terminals in reply to Ralph Butteris, 10-10-2001 06:53:06
A quick bath in baking soda water, or even soda pop - lemon lime works well, will clear the corrosion off quickly. Is good to cover battery terminals with a light coating of grease before assembly - puts off next bath a long time!
Kim
10-10-2001 07:30:42
Thanks Ralph, could you clear up for us what common "CLR" is?
Kim
Tom-Pa
10-10-2001 09:20:18
 Re: Re: quick easy way to clean electrial terminals in reply to Kim, 10-10-2001 07:30:42
CLR stands for calcium,lime,rust. You can pick up a container of CLR at your local supermarket in the household cleaning items shelves. CLR is the name of the product. This is a cleaner.
FM
10-10-2001 09:17:58
Kim, CLR is a common cleaning product for Calcium, Lime, Rust. Use it in toilets and such(rust stains, etc.)
