Restoration & Repair Tips Board
JD 730 Hydraulic Pump
TxTed
12-04-2007 15:25:45
A frind of mine as John Deere 730 diesel, with leaking seal on the hydraulic pump. He has the I&T JD-11 sevice manual, he has removed the three bolts that hold pump in. Tried driving a chisel between pump and tractor, could not move pump. Does any one know of a way to pull pump?
In I&T manual JD-11 paragraph 191 is a picture of pump, is there any thing beside the three bolts holding the pump? All lines are loose.
Mike M
12-05-2007 12:30:29
 Re: JD 730 Hydraulic Pump in reply to TxTed, 12-04-2007 15:25:45
Maybe a 4th bolt ? I'd have to check a parts book for sure.
