Restoration & Repair Tips Board
Filed off serial numbers
George Landrum
12-07-2007 12:36:16
A machinist told me there is a process called acid dating in which a filed off serial number on an engine block, or other metal, can be retreived. Can someone give me some info on this?
Thanks
unclefuf
12-08-2007 18:44:46
 Re: Filed off serial numbers in reply to George Landrum, 12-07-2007 12:36:16
Would this work on an aluminum tag that was sandblasted??
davediehl@hotmail.com
12-09-2007 15:51:01
 Re: Filed off serial numbers in reply to unclefuf, 12-08-2007 18:44:46
As long as the numbers were pressed in.
Fancy Farm
12-07-2007 20:34:55
Will that work on cast iron?
Davis In SC
12-07-2007 19:11:22
The Law Enforcement agencies can do that on guns that have #'s filed away, so I assume it would work on an engine block.
12-07-2007 23:36:21
 Re: Filed off serial numbers in reply to Davis In SC, 12-07-2007 19:11:22
This only works on stamped steel like guns and items with press stamped numbers. This does not work on items with cast or raised letters. Anyone that tells you it can has been watching too much CSI.
noncompos
12-07-2007 18:10:56
Can"t answer authoritatively, but can say can be done under certain circumstances---never looked it up but assume has to do with stress of stamping numbers or letters into metal affecting the metal below the visible impressions. Would guess--repeat, guess--would work best where not much underlying metal could be removed...
