Restoration & Repair Tips Board
K-301 how to remove cam shaft?
Wydra
12-10-2007 14:35:32
Got a total tear down of a 301 Kohler engine and was wondering what is the secret to removing the cam shaft?
Bob
12-12-2007 07:47:13
 Re: K-301 how to remove cam shaft? in reply to Wydra, 12-10-2007 14:35:32
The "rod" that the camshaft rotates around has to be pressed out.
With the aluminum bearing plate on the flywheel side removed, press on the PTO side (engine output shaft side) of the rod, forcing it out the flywheel side.
Take note where the cam thrust washer(s) is, so it can be put back in the correct side.
Re-install it from the flywheel side. I always put a little low-strength LocTite in the hole at the PTO side, just before pressing the shaft in frommthe other side, to ensure no oil seeps past the rod.
steve from mo - dangit!
12-12-2007 08:04:00
 Re: K-301 how to remove cam shaft? in reply to Bob, 12-12-2007 07:47:13
On reinstallation, measure the cam end clearance and shim back to spec. Failure to do so is one cause of K-series knocking.
