Timming an 8N
Charles VanScoy
04-30-2002 15:05:54
What is the best method to get #1 cylinder TDC?
I have tried removing the plug, inserting a rigid wire but had no luck.
Charles (TX)
05-02-2002 12:55:55
 Re: Timming an 8N in reply to Charles VanScoyk, 04-30-2002 15:05:54
Charles, the 8N spark plug sets over the valves and not the piston so there is no good way to feel around through the plug hole for TDC. On #1 cylinder, bring it to compression stroke by hand turning the engine and then look thru the porthole at the flywheel and bring it around to 4deg. This will bring you to TDC. Good luck.
