Restoration & Repair Tips Board
1952 allis chalmers b
Rick Walker
12-15-2007 16:59:23
2 part question
1 it runs great for 1/2 hour then will only run with full choke?
2 It takes a 1/2 hour or better before the hydraulics will work what is the lightest weight oil i can use for the winter
jerry n
12-24-2007 06:36:30
 Re: 1952 allis chalmers b in reply to Rick Walker, 12-15-2007 16:59:23
reply to first question, i have a 1936 allis wc
and had some problems with it quiting after running for a short time, it ended up to be the
gas cap vent holes were plugged, good luck jerry
rick walker
12-24-2007 08:24:59
 Re: 1952 allis chalmers b in reply to jerry n, 12-24-2007 06:36:30
as it turns out the pipe out of the tank was plugged solid. thank you very much for your tip
rick walker
12-24-2007 08:24:56
old
12-15-2007 18:49:58
Well problem #1 check you gas flow out both the drain plug and the main jet. You need to get a good flow out both for 5 plus minutes. Most C carbs have a non adjustable main jet and they do cause problems like that some times. Thats why I say check flow at both places and some time doing that will clear up your problem. #2 you can use Hy-tran or a trans-drolic type fluid which is a lot thinner to speed things up in cold weather
Rick Walker
12-17-2007 18:12:36
 carb in reply to old, 12-15-2007 18:49:58
is hard to rebuild? i am fairly mechanically inclined.
old
12-17-2007 19:16:32
 Re: carb in reply to Rick Walker, 12-17-2007 18:12:36
Those carbs are very simple but hard to get all the passages as clean as they need to be. Kit will cost around $20 give or take a little depending on where you buy it
