Starter not turning
fred(MI)
05-01-2002 06:16:24
i have a 1940 farmall h that i bought about 7 months ago. i went out to start it 2 weeks ago and the starter won't turn the engine over. i took the starter out and hit the button and it turns fine.any ideas of what could be causing this? thanks for any help.
(p.s when i bought it it had new rings and a rebuilt head put on it.)
Greaseman
06-07-2002 16:28:25
 Re: starter not turning in reply to fred(MI), 05-01-2002 06:16:24
If the starter wants to turn but not "fast enough to turn the engine overthen, chances are the starter needs a rebuild or replacemnent". I would also look into the starter "hole" and see if you see where it's might be possibley hanging up on something. I would remove the starter, then tow the machine around and attempt to "Pop the clutch" if the engine is free, then the starter should be checked by a competent electrical motor company, I had bad luck with NAPA.
Red Dave
05-01-2002 06:25:28
Those starters have a habit of not disengaging from the flywheel once and a while. Maybe it was stuck?
I'd put it back in, make sure all the connections are clean, tight and bright, and see if it works now.
When a starter sticks, you can often free it by loosening the bolts about halfway, wiggle the starter around some, then bolt it back up.
Hope that helps.
fred(MI)
05-02-2002 12:36:31
 Re: Re: starter not turning in reply to Red Dave, 05-01-2002 06:25:28
i put it back in and it still is not turning the motor over. i sure hope there isn't any thing caught in the engine.
Red Dave
05-03-2002 06:20:09
 Re: Re: Re: starter not turning in reply to fred(MI), 05-02-2002 12:36:31
Can you turn the engine by hand?
You may want to ask about this over on the Farmall/IH board. Some of the guys on there are really good with H's.
