Restoration & Repair Tips Board
Loose Sleeve
Byron H
12-19-2007 17:56:57
My brother bought a 2000 Ford gas burner. At idle the engine knocked. When you idle it up the knock would stop. He tore it down and found when he pushed out the #2 piston the sleeve came up. He got the piston out and pulled the sleeve out with his hand. If anyone has a solution to this problem, please reply. There is no apparent damage to any parts.
Larry Condon
12-21-2007 05:51:07
 Re: Loose Sleeve in reply to Byron H, 12-19-2007 17:56:57
Make sure that the head is holding the sleeve down tight. When the sleeve is installed measure how high it sets above the block, should be at least .003-.004 above.
Larry
soundguy
12-20-2007 20:42:55
2nd ditto on the loctite sleave retainer after cleaning the sleave and bore..
soundguy
Weldin man
12-19-2007 19:42:58
3 cyl or 4 cyl 2000? Was the engine sleeved originally or is it a repair sleeve? Oversize sleeves are available for some engines. Loctite makes a sleeve retaining compound that works pretty well. Some people use a thin epoxy. I have seen a few N series Fords slip sleeves and some perkins over the years,not all that uncommon.
ldj
12-20-2007 17:50:03
 Re: Loose Sleeve in reply to Weldin man, 12-19-2007 19:42:58
I had a jubilee do that. I used loctite, just the plane strong one, not sleeve retainer. It worked 4 or 5 years I know. Don't know how much longer because I sold the tractor. The sleeve was so loose I also pulled it out with my hand. I cleaned the sleeve and bore real good lacquer thinner then brake cleaner.
