Restoration & Repair Tips Board
snow thrower problem
apcjr1967
12-31-2007 11:19:40
My snow thrower recently stopped going in F or R. Anyhting I should check for?
Everything else seems to operate fine.
rustyj
01-01-2008 11:38:20
 Re: snow thrower problem in reply to apcjr1967, 12-31-2007 11:19:40
Give us some maker names, model numbers, and anything that will help us identify your problem! There are several makes and types out there--we have to know exactly what you have, and then we might be able to help! By: Rustyj
Yugrotcart
12-31-2007 13:42:26
Assuming it is a gas powered self propelled model.
A- Drive axle just frozen. Drag it forward, drag it backwards or thaw it out.
B- A bolt or shear pin or split pin on the axle has broken or fallen out. Remove the inspection cover from underneath and have a look.
Paul
