Restoration & Repair Tips Board
power adjust rim repair
arch
01-03-2008 16:29:20
Has any one ever cut the rail out of a rim and put them back in a an other rim.A 6 loop rim is $144.00 and p a is $375.00. IF some one has done how did you do it????? Thanhs Archie
Dick L
01-05-2008 07:09:43
 How Bad Is The Old Rim in reply to arch, 01-03-2008 16:29:20
The larger repais starts at the bottom of the page/album at the link.
Arch
01-04-2008 16:37:31
 Re: power adjust rim repair in reply to arch, 01-03-2008 16:29:20
Thanks Kansas Cockshutt I went today to tractor parts place looked in back of room and found a 12 by 28 blank rim for 75.00. Stsrt tomommo m cutting my rails out. Arch
Kansas Cockshutt
01-03-2008 23:02:43
use your hub as a template, tack, make sure it does not bind spun in and out. there is a lot more play then you think, at least on the 4 rail I did. Depends on how long winter is but I have found it is better to snoop around and find used rims then mess with all the labor and rods to burn. Might be different in your area. Good luck, and watch out for that calcium! ha ha couldn't help myself :-)
arch
01-06-2008 16:42:33
 Re: power adjust rim repair in reply to Kansas Cockshutt, 01-03-2008 23:02:43
third party image
third party image
third party image
third party image
third party image
third party image
this is power adjust rims, took me around 8 hours to fix these. inclosed are some pictures of reapired rims, old rims which i made templtae used for marking, picture of my 135 massey fergusen, picture of new tires which will soon be instaled, and picture of the template i used. thank you very much kansas cockshutt.
Henry Wixon
01-28-2008 17:47:49
 Re: power adjust rim repair in reply to arch, 01-06-2008 16:42:33
Archie: Great looking job on that PA rim. I have double the problem - both PA rims on my Ford 640 are shot, and I can't find used ones. You said you found a "blank rim." Do you know if the 12-28 Flat Base rim (W1228 in Gempler's catalog) would work to fix a 12-28 PA 4-rail? Are these PA rims standard items or do they vary from tractor to tractor? Can I weld the rails in with gas or will I need to arc-weld? Thanks for any help on this.
