Restoration & Repair Tips Board
John Deere AR rear end sludge
Ryan James W.
01-06-2008 10:07:35
HI, I Have a 41 unstyled John Deere AR that was full of water and sludge in the rear end. All of the rear end lube turned to jelly. What is the best way to get the sludge out of the bottom? Is it alright to try putting gasoline or diesel fuel in the rear end to dissolve the sludge or does it need to be ripped apart? Thanks for your help, Ryan
noncompos
01-06-2008 20:05:40
 Re: John Deere AR rear end sludge in reply to Ryan James W., 01-06-2008 10:07:35
Ryan, your question pretty much depends on time and circumstances...you didn't say how long the water was in there, or whether it was run or worked with water contamination. I'm not familiar with your machinery, but if it's been messed up long enough to gel, it sounds like you need to eyeball it (assuming your post doesn't mean you already have), if there's any way to do so without a complete teardown.
I assume when you try to flush it it'll be jacked up and under no load; when you drain your flushing fluid, use a clean pan and look for rust particles or metal shavings (we used to use a little magnet, altho some metal wasn't magnetic)...
greenmech
01-06-2008 18:39:44
Ryan , I would use diesel or kerosene , run the gears some and drain. If you can, open it up and wipe out the bottom. I also have a 41 AR ,last one built in 41. Ron Mn.
Ryan James W.
01-07-2008 18:50:20
 Re: John Deere AR rear end sludge in reply to greenmech, 01-06-2008 18:39:44
Hey thanks a lot Ron that's neat to know. My AR is the 854th built in 41.
