Restoration & Repair Tips Board
ampmeter wiring on ford naa
cain
01-07-2008 16:42:49
ofcourse after replacing a voltage regulator and belt on the tractor I just bought.....trying to figure out why the ampmeter was reading -1amps I saw the ampmeter was not hooked up. It has two studs coming out of the back, with a red wire off of one and a white wire off the second stud.
Does anyone know what I could attach these to so I get an amp reading while i'm using the tractor? Thanks!!!!!
cain
01-07-2008 17:23:09
 Re: ampmeter wiring on ford naa in reply to cain, 01-07-2008 16:42:49
Bob..... THANKS! This was a huge help.
Bob
01-07-2008 16:54:49
 Diagram... in reply to cain, 01-07-2008 16:42:49
If it's "as-original", 6-Volt, here you go... the ammeter connects between the battery cable side of the starter solenoid and a stud on the insulated terminal block.
Third Party Image
A 12-Volt conversion should be SIMILAR to this digram for a converted LATE 8N:
Third Party Image
