Restoration & Repair Tips Board
Can you disassemble and reassemble diesel injectors?
scott#2
01-15-2008 15:15:55
The manual says that you can take them apart and put em back together. I would just run them but water got into the combustion chamber and the injectors are a little cruddy. I took the head off and pulled one out and mistakenly took the base off when it came out of the head. Looking at the manual, they seem pretty straight forward. Or should I just send them out?
Thanks,
scott#2
old
01-15-2008 15:58:46
 Re: Can you disassemble and reassemble diesel injectors? in reply to scott#2, 01-15-2008 15:15:55
I would send them out. The reason is they need to be adjusted for what pressure they should work at and since you opened them up you may not get them set as they should be
msb
01-16-2008 19:19:24
 Re: Can you disassemble and reassemble diesel injectors? in reply to old, 01-15-2008 15:58:46
On some nozzles the tip has to be oriented a certain way. If they are reassembled wrong, the spray pattern can cut a hole in top of a piston, depending on the manufacture. Once they are disassemblied it is almost always a necessity to lap the mating surfaces if you don't want them to leak.Send them out.
