Restoration & Repair Tips Board
Re: hydraulic leak from a screw?
Amarillo Doug
01-17-2008 10:11:09
Those are not screws .They are a load check valve as well as I remember.They are held in by a wire type snap ring and have O rings on them.If they are leaking you should pull the valve off they tractor and replace all the O rings.Did this many times while working for CaseIH.
benjaminR
01-17-2008 18:11:36
 Re: hydraulic leak from a screw? in reply to Amarillo Doug, 01-17-2008 10:11:09
I looked for a snap ring, and couldn't find one. The only thing I could see, on the right side of the valves is a bolt head in line with these two things, and is it possible could be locking them from inside the valves?
I am up for undoing all the connections and replacing the o rings, but how tricky is that?
I am not a mechanic, but a very hands on, heads up person. Can I undo the connections, undo the bolts, clean, replace and it will work again? What do I do about oil pressure? I have ordered the manual to the tractor, but haven't recieved it yet, and don't know how detailed it will be.
Thanks for your help
Brn
