Restoration & Repair Tips Board
Case VAI HELP???
tjeepinit
01-19-2008 06:17:22
I have a 1952 Case Vai with no spark. She has been converted to 12 volt. Instead of explaining everything I have tried would someone please get me restarted and researching what might be the problem. I installed GMs single wire alternator. new ignition. I have power going in but none coming out. Thank you your help means a great deal to me!!
Tim Fisher
mj
02-21-2008 10:39:11
 Re: Case VAI HELP??? in reply to scott Dewitt, 01-19-2008 06:17:22
tjeepinit said: (quoted from post at 20:18:37 01/21/08) Is there a coil if its a magneto? Is there somewhere online I can obtain a wiring diagram??
There is no coil if the tractor has a magneto. For wiring diagrams -
Look here ➔ Link
DS Mi
01-21-2008 17:54:36
 Re: Case VAI HELP??? in reply to tjeepinit, 01-19-2008 06:17:22
Did you change coil? or put in a resister? Assuming it's a distibutor. Do you have power to coil? Sometimes the little things catch us off gard. good luck DS
tjeepinit
01-21-2008 18:18:37
 Re: Case VAI HELP??? in reply to DS Mi, 01-21-2008 17:54:36
