1952 B generator
Roger Hall
05-07-2002 06:33:10
I'm replacing an alternator on my B. Could someone tellme the appropriate place to mount the regulator so that I can put the right generator on. I have seen the regulator strapped to the gen. by hose straps, but this doesn't look like it would have been original.
Jim in UK
08-11-2002 07:19:03
 Re: 1952 B generator in reply to Roger Hall, 05-07-2002 06:33:10
On the Farmall "B" if I remember correctly the regulator is also mounted on the generator with bolts like on the John Deere "B".
Jerry S
05-07-2002 08:37:36
I don't know which kind of B it is you have but if it is a Deere, the generators have the regulator mounted right on top like you describe except it bolts on not just clamped on. I myself am looking to get an alternator put on my tractor because they are sure a lot more reliable. The generators are sure expensive to repair.
