Restoration & Repair Tips Board
Ferguson TO35
mike wheatley
01-30-2008 20:49:56
This message is a reply to an archived post by Chester2 on August 24, 2005 at 17:49:25.
The original subject was "Ferguson TO35".
I just purchased a 1955 TO35 for restoration. Gear Oil is leaking around the PTO shaft. I want to replace the Oil Seal. How do i get the Oil Seal Retainor out? Does it Screw out and is it standard [righte tighty lefty loosie] thread?
Jerry/MT
01-31-2008 11:14:17
 Re: Ferguson TO35 in reply to mike wheatley, 01-30-2008 20:49:56
Go the Ferguson Forum and ask this question. It"s been answered before.
The entire pto can be removed by removing the four nuts from the bearing housing at the back and pulling the whole assembly out. You will need to drain the transhydraulic oil out(~5-6 gallons) or park the tractor with the front end in a deep ditch before you try to remove the pto shaft.
MIKE WHEATLEY
01-31-2008 15:57:06
 Re: Ferguson TO35 in reply to Jerry/MT, 01-31-2008 11:14:17
JERRY,THANKS FOR THE HELP AND THE TIP. I NEED TO DRAIN THE FLUID ANYWAY SO I'LL DO THAT FIRST. MY OTHER PROBLEM IS, ALL THE BOLTS ARE ALREADY REMOVED. THE TRACTOR CAME TO ME THAT WAY. I PURCHASED A MANUAL AND I AM LOOKING AT THE PARTS INVOLVED WITH THE PTO. ON PAGE 176 OF MY MANUAL PART #9 TITLED RETAINER, OIL SEAL IS THE PART THAT I AM LOOKING AT WHEN I LOOK AT MY PTO. IT HAS EVIDANCE THAT SOMEONE HAS USED A HAMMER AND CHIZEL TO TRY TO REMOVE IT. SO NOW MAYBE YOU WILL BETTER UNDERSTAND MY PREDICEMENT. ANY FURTHER SUGGESTIONS AS TO HOW TO GET THIS THING OUT. ALL SUGGESTIONS ARE TRULY APPRECIATED AND I WILL LOOK THE FERGUSON FORUM FOR ANSWERS.
THANKS AGAIN FROM SOUTH MISSISSIPPI
Jerry/MT
01-31-2008 20:50:27
 Re: Ferguson TO35 in reply to MIKE WHEATLEY, 01-31-2008 15:57:06
It sounds like you all ready have the shaft our of the tractor, Mike. Is that correct? I am not familair with the specifics of TO-35 but I think it is very similar to the other TO"s.There are some snap rings that have to be removed and the bearing and the seal are pressed off.
Starting from the front, there should be a snap ring, then the bearing and another snap ring, then an oil seal and sleeve and another snap ring, a gasket, and the pto cover (with the bold holes). The retaining bolts are 7/16 x 1" NC I believe. I hope this helps.
