Restoration & Repair Tips Board
GAS TANK REPAIR
duck1
01-31-2008 07:09:44
i know this topic has been run into the ground but can someone give me a correct simple yes/no answer for the following question? if i prep the outside of my massey 410 gas tank (bottom side by seam) can i overlay all my previous patches with a fiberglass patch along the whole bottom and will it stick and stay?
mj
02-21-2008 10:16:48
 Re: GAS TANK REPAIR in reply to Jake T., 01-31-2008 07:09:44
duck1 said: (quoted from post at 09:09:44 01/31/08) i know this topic has been run into the ground but can someone give me a correct simple yes/no answer for the following question? if i prep the outside of my massey 410 gas tank (bottom side by seam) can i overlay all my previous patches with a fiberglass patch along the whole bottom and will it stick and stay?
Once you get all of the fiberglass off cut out the rusted parts and sheet the whole area with a piece of galvanized sheetmetal. If you use a soldering copper you don't have to worry about fumes igniting, either. 8)
Frank A
02-18-2008 16:24:57
 Re: GAS TANK REPAIR in reply to duck1, 01-31-2008 07:09:44
I'd say no.But I'd say no to fiberglass for a gas tank repair anyway.
glennster
02-01-2008 10:25:08
if you apply glass over an old patch, it prolly wont last long. is the old patch weeping fuel? if so , the patch is already separating, and should come off before applying a new patch. i would recommend you have a liner put in the tank first to keep the fuel off the patch. if the bottom of the tank is really bad with bigger holes, you may need to patch first, then put the liner in.
djw
02-01-2008 10:16:47
I know this doesn't answer your question, but I used Napa's red coat tank liner last year and it works excellent. But you do need to remove the tank to use it. Dave
Joe (Wa)
01-31-2008 19:23:39
The correct yes or no answer is maybe.
Joe
k deere
01-31-2008 13:47:30
no if any of existing is lose it should be fully removed!!!!!
