Restoration & Repair Tips Board
Penetrating Oil - Comparison Test Results
Lee Aanderud
02-05-2008 15:51:26
Copied this off the Studebaker forum website:
"The April/May 2007 edition of Machinist's Workshop did a test of penetrating oils where they measured the force required to loosen rusty test devices. Buy the issue if you want to see how they did the test. The results reported were interesting. The lower the number of pounds the better. Mighty interesting results for simple acetone and tranny fluid!
Penetrating oil . Average load .. Price per fluid ounce
None ..... ..... ..... 516 pounds .
WD-40 ..... ..... .. 238 pounds .. $0.25
PB Blaster ..... ... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ..... .. 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio)."
RichardR
03-17-2008 08:07:12
 Re: Penetrating Oil - Comparison Test Results in reply to Lee Aanderud, 02-05-2008 15:51:26
I was told that peroxide would work. I tried it recently on some stuck bolts and it worked where WD 40 didn't. Just another input.
mj
02-21-2008 10:10:05
 Re: Penetrating Oil - Comparison Test Results in reply to Oldarkie, 02-05-2008 15:51:26
[quote:a50087c621]GM has one that is both a penetrant and a rust remover. It's designed to be used on heat pipes on exhaust manifolds. It's a clingy type and works well.
jb[/quote:a50087c621]
bradk said: (quoted from post at 12:29:47 02/10/08) Goodwrench heat valve lube.Mopar sell a similar spray.
Yeah, that's good stuff! :)
john_bud
02-09-2008 21:19:43
jb
bradk
02-10-2008 10:29:47
 Re: Penetrating Oil - Comparison Test Results in reply to john_bud, 02-09-2008 21:19:43
David Maddux
02-07-2008 20:18:07
I think my favorite is Gibbs.
hay
02-07-2008 13:21:52
try pure undiluted antifreeze straight from the jug. works great as a penetrating fluid and a soaking fluid. too bad it's not avaiable in a spray can.
D13
02-07-2008 04:45:16
Very interesting. I know WD stands for Water Displacing and I quit using it as a penetrant years ago (keep a can for wet ignitions though). I have both Kroil and Blaster and find Blaster works better unless I'm going to heat the part, in which case Kroil seems to work better. I use ATF for soaking since it's chaeap and I'm not in a hurry. Haven't tried the ATF/acetone mix.
msb
02-06-2008 10:09:22
 Interesting in reply to Lee Aanderud, 02-05-2008 15:51:26
Thank you. I'll try it. Might be the trick for a stuck engine.
