Lift problems
D. Adams
05-08-2002 16:47:04
Need help with the hyd lift on a 5211 Zetor. It lifts fine but drifts back down fairly quickly and then raises back up on its own. Pulsates up and down as long as you have a load on the lift.
Unimog
05-09-2002 13:23:25
 Re: lift problems in reply to D. Adams, 05-08-2002 16:47:04
Does it leak down when the tractor is shutdown?
If so it is likely the rubber packings in the
internal cylinder are bad. There are 2 U-cup seals
on the piston that would need replacement.
Unimog
D. Adams
05-09-2002 18:46:45
 Re: Re: lift problems in reply to Unimog, 05-09-2002 13:23:25
I think it does leak down when it is shut down. I will check to make sure. Thanks for the help.
Unimog
05-10-2002 05:20:41
 Re: Re: Re: lift problems in reply to D. Adams, 05-09-2002 18:46:45
Another thing to check is the lift handle. There
is a friction brake which holds the handle in
place and it gets loose sometimes. It can be
tightened at the rear of the tractor. Vibration
causes it to loosen and lets the hitch leak down.
Unimog
D. Adams
05-10-2002 19:55:11
 Re: Re: Re: Re: lift problems in reply to Unimog, 05-10-2002 05:20:41
Could the relief valve cause the lowering of the lift?
Unimog
05-11-2002 20:00:20
 Re: Re: Re: Re: Re: lift problems in reply to D. Adams, 05-10-2002 19:55:11
The relief valve or line being loose sure could
cause the problem. All should be checked before
taking any corrective service. The MOST likely
problem remains the u-cup seals.
Unimog
D. Adams
05-12-2002 18:40:10
 Re: Re: Re: Re: Re: Re: lift problems in reply to Unimog, 05-11-2002 20:00:20
You were correct. The rubber seals on the lift piston are now in very small pieces. Now to find new ones. I have a few places to try. Thanks again for your help.
Jerry B
05-09-2002 05:38:35
Sorry I wasn't of any help.
