Restoration & Repair Tips Board
hitch not working
UU
02-07-2008 14:16:16
Thanks for the info.I can tell you know alot about these tractors. First of all i should say that this is my first tractor & it is in a severe condition . Here are some pics to show how bad it is...Copy the link and paste in your address bar.
Link
MB
02-08-2008 08:56:41
 Re: hitch not working in reply to UU, 02-07-2008 14:16:16
The lift cylinder is under the seat on the bottom side of the casting the seat is attached to. The lines running to the front are for the hydraulics, but just go to an oil cooler on the front in the radiator. The black knob on the side is either the flow control or diverter knob. The diverter is what shuts off pressure to the lift arms. It pulls out to cut off the flow. It should be marked with what it is. I see a shaft stiking oput just behind it that may have been the flow control, but he knob is missing. Looks like you've got your work cut out for you. I would suggest getting an I&T repair manual and operators manual. They are available on this website under "Marketplace", just look for the 6610 series. For parts, look on te web for tarctor salvage yards. They all have wreaks that can be salvaged for many of the parts you need. Also, a lot of places sell aftermarket parts for the older Ford tractors. Not sure what is avail in Jamaica, Doesn't look like any major components need replacing. Hope this helps
UU
02-08-2008 09:18:25
 Re: hitch not working in reply to MB, 02-08-2008 08:56:41
Thanks,Thanks,Thanks, I feel relieved as i thought that it was a gearbox. Hydraulics, no problem. I will search for tractor salvage yards online. Will i need special tools to change wheel seals?,on semi"s we use these large sockets around 4 inches.By the pics i think these are different.
MB
02-08-2008 11:52:31
 Re: hitch not working in reply to UU, 02-08-2008 09:18:25
I don't think so. I haven't changed any but I know you will have to pull the axle shaft to get to them. The I&T repair manuals will let you know if you need a special tool, although all the tractors and equip I have worked on I have found workarounds for nearly every special tool (shade tree mechanic). Removing the axles will require taking the top off the rear end. Be careful pulling the top as that has the hyd lift cylinder as part of the top plate and there may be some lines that run down into the rear end that would come out with the top plate. A lot of this will depend on the year and options on the tractor.
RickB
02-16-2008 10:46:02
 Re: hitch not working in reply to MB, 02-08-2008 11:52:31
I have yet to see a Ford tractor that requires the hitch cover to be removed in order to pull an axle housing. Best money the original poster can spend is on a service manual, preferably the factory manual from New Holland.
