Restoration & Repair Tips Board
Int, 3414 front hydraulic cyl, seal change
Terry Braley
02-14-2008 12:10:43
I need to change the seal on the front right cyl, when I operate the bucket it leaks ALOT of hydraulic fluid. How hard is it to change?
Boblang
02-20-2008 23:57:19
 Re: Int, 3414 front hydraulic cyl, seal change in reply to Terry Braley, 02-14-2008 12:10:43
You should find a hydralic company that rebuilds cylinders because your cylinder could be scored and if you just put in new seals the cylinders could just screw up the seals. thats my two cents worth
