Restoration & Repair Tips Board
allis chalmers c engine piston position
brian cockerill
02-17-2008 18:54:33
I took the pistons out of the block of an allis chalmers C. I know which pistons go in which cylinder but I think I made a mistake and mislabeled left from right. Can someone advise me which is the right side of piston and which is the left. There appears to be a difference.
Thanks.
Dick L
02-18-2008 06:41:34
 Re: allis chalmers c engine piston position in reply to brian cockerill, 02-17-2008 18:54:33
The rods on this engine, on the journal end(large end) are off set, and the wide side on number one goes toward number two. the wide side on number two goes toward number one. Same on three and four, the wide sides go toward each other. The rods have the oil funnels on both sides.
The pistons do not have a right or wrong way as in some engines.
The rod on the left side would be the one like you have. The one on th eright is from a D-15
third party image
Bob
02-17-2008 19:14:39
Have they been removed from the rods? if not, and the rods are numbered, the number goes toward the camshaft side of the engine.
