Restoration & Repair Tips Board
case 730 comfort king problem
gc
02-18-2008 19:07:40
I am having problems with my 730 case it is a gas engine it starts easily idles up when choke is on then after 30 seconds dies - so far i have changed the carb and gotten it rebuilt, changed the feul line and sediment bowl cleaned the tank and added an in tank strainer, checked the ingition switch, ckecked the plug wires there is good spark on all of them changed the plugs i am at a loss is there something i am missing?
shawnspeed3
02-19-2008 09:38:46
 Re: case 730 comfort king problem in reply to gc, 02-18-2008 19:07:40
Ballast resistor???It's on the plate between engine and gas tank??? usually when they are bad the engine turns off after you let the key into the run position, but it could be getting hot and shorting, remove it and see if the tractor stays running ,(Connect the 2 wires together) all it does is knock the voltage down to 6 V for longer point life. Mine did that until I cleaned the fuel system, but it sounds as if you did that already...good luck Shawn
J Heitkemper
02-18-2008 19:23:34
Gc ,HUUMMM,, right after she stalls out shut off gas , Then drain carb pitcock to see How much gas comes out , if NONE THEN SHE"S STARVING OUT OF FUEL,, Best off to, Bring this problem over to the Case bd ,
