Hydraulic activation with clutch activated?? MF TEA-20
Christian
05-10-2002 15:48:29
I wonder if there is any way i can use my hydraulic system when the clutch is pressed down on my Ferguson TEA-20 1954 mod.It is causing me a lot of problems when moving snow.
Duner Wi
05-12-2002 15:35:22
 Re: Hydraulic activation with clutch activated?? MF TEA-20 in reply to Christian, 05-10-2002 15:48:29
Go to the Ford 9N board and search for livethang.
Zane Sherman has made such a device for the Ford 9 2 8N and TO Fergusons. Not sure how it would work on the TEA but if you were clever I bet you could get the pump to run with his kit on a TEA.
David McLean
05-21-2002 04:16:01
 Re: Re: Hydraulic activation with clutch activated?? MF TEA-20 in reply to Duner Wi, 05-12-2002 15:35:22
I'd be interested to know if there is a way to do this as I can't see how its possible given that the T20 has a single stage clutch. When the clutch is down nothing aft of the engine flywheel turns, including the hydraulic pump. However, people are very inventive and maybe there is a way...
