Restoration & Repair Tips Board
Cleaning W-6 part's,
kirk in ks,
02-21-2008 12:55:46
whats the best way to get the large tractor wheels off the back of this W-6 to beadblast them and clean them up?
I guess I could get the outer rim off 1st and then the inner one later and blast the rims primer them and paint them and that would be done,
then do the same to the fronts, and they would be done,
glennster
02-21-2008 13:13:54
 Re: Cleaning W-6 part's, in reply to kirk in ks,, 02-21-2008 12:55:46
definately separate the rims from the hubs, those center castings are heavy as heck and the wheel is off balance if you try to take em off in one piece. the rear casting is held on with a bolt in the center, but the shaft is splined and can be a bugger to get off the shaft. lots of penetrating oil. you may need to build a puller to get the hub off. be sure the tire isnt loaded with chloride too, if so pump it out first.
