Restoration & Repair Tips Board
Rusty Gas Tank
Ron in OH
02-23-2008 04:22:08
Has any one used E85 and sand to clean a rusty gas tank ? What have you found is the best way to go about this.
gots-2-go
02-29-2008 06:36:32
 Re: Rusty Gas Tank in reply to Ron in OH, 02-23-2008 04:22:08
We had a gas tank that was from a Farmall H, it had been empty for a long time and was bone dry inside.
Dad put about a coffee cup of 1/4" nuts in it, replaced the cap and strapped the tank to the rear wheel of a M, then told my little brother to go ride around for about an hour.
When he removed it he dumped out the nuts and the tank was super clean inside. He sealed the tank with a product that he got at a motorcycle shop in town.
Dale in WV
02-29-2008 05:06:51
Local repair shop has essentially a rotissery system setup -- they clamp the tank in the rotissery, add some abrasive product and rotate it for a number of hours; next they rotate the tank 90-degrees and rotate it along the next axis for a few more hours. Then a clean and purge and like the gentleman said coat it with the red stuff.
Mark Doud
02-27-2008 13:33:38
Fill it full of coarse gravel and kero, throw it into the back of the truck, and drive around for a couple of weeks.
Works pretty well.
Richard S. Webster
02-24-2008 05:35:55
Any good size motorcycle shop will carry a two part gas tank sealer.I have used this product with great success in the past but cannot remember the name.This product is white and when it set's up it has a marble like finish that rust,solvent's,or just about any chemical will not harm.
DaveS
02-27-2008 03:51:25
 Re: Rusty Gas Tank in reply to Richard S. Webster, 02-24-2008 05:35:55
I have some of that in my shop but I cant remember the name of it... It does work good.
DaveS
02-29-2008 17:26:58
 Kreem sealer in reply to DaveS, 02-27-2008 03:51:25
That's the name of it.
justin14054
02-23-2008 08:00:29
Mauratic acid $5a gallon(2 gallons).Rinse well after done and coat.Dont breathe the fumes
My $.02 worth
Justin
rrlund
02-23-2008 07:14:44
I just whack'em with a rubber hammer then rinse them out with water. Let'em dry and coat the inside with Red Kote.
GeneMO
02-23-2008 05:03:33
Sounds like a bomb to me. I would be worried about a spark!
Gene
DaveS
02-27-2008 03:53:16
 Re: Rusty Gas Tank in reply to GeneMO, 02-23-2008 05:03:33
If you are getting sparks, That is one bad a$$ rubber hammer.
Ron in OH
02-23-2008 10:22:36
You are probably right. I heard a guy make a statement one time that E85 was great to clean rusty tanks. I have four to do sometime soon and I thought about that statement. Not worth the gamble.
D13
03-13-2008 06:56:59
 Re: Rusty Gas Tank in reply to Ron in OH, 02-23-2008 10:22:36
The E85 acts as a solvent to lift the old varnish from the evaporated gas. Doesn't do a thing for rust.
I flushed mine with acetone, then did the nut trick, then soap, water, dry, and lined. POR-15 the outside prior to paint.
