Zetor air compressor
D. Adams
05-10-2002 20:02:05
I have an air compressor on my Zetor 5211 but do not know how to engage it. I see two levers on the compressor but do not know what to do with them without breaking something. Thanks
mike miller
01-11-2004 16:09:16
 Re: Zetor air compressor in reply to D. Adams, 05-10-2002 20:02:05
Did you ever figure out your comprssor on the Zetor? I have an older (84) Tractor sold under the name Agripower 5000. There is a lever that engages the compressor but first there is another one that must be pulled to unlock it. The engagement lever is further up and toward the front, where the locking lever is lower and at the rear of the compressor. I have never hooked up an air hose so not sure how well it works. Mine is 3 cyl diesel 46 HP and has been a good work horse for my small 35 acre parcel. Unfortuantly i let the engine Freeze up and now after replaceing several freeze plugs still have anti freeze getting into the oil. My son is suposed to be taking the heads into his diesel school to magniflux, and I'm pulling the sleeves to replace the o-rings. Being a wet sleeve design, i can't see where else it would be mixing the two fluids.
