Restoration & Repair Tips Board
Ford 3000 Diesel, think it is a 1972 model
Dwayne Buckley
02-29-2008 08:17:27
Just bought a Ford 3000 diesel [1972?] it has about 9 inches of slack in the steering wheel before any of the steering links begin to move. It has power steering and otherwise works fine. I have orded a manuel. But thought someone might be able to advise me. Give me a clue. Thanks Dwayne
dieselpaul
03-02-2008 12:35:24
 Re: Ford 3000 Diesel, think it is a 1972 model in reply to Dwayne Buckley, 02-29-2008 08:17:27
probably the steering shaft bearings or adjuster nut on p/s reaction unit backed off.look & see if steering wheel moves up & down a bunch when turning. its designed to move slightly to direct fluid, but not much.
Dwayne Buckley
03-05-2008 09:27:48
 Re: Ford 3000 Diesel, think it is a 1972 model in reply to dieselpaul, 03-02-2008 12:35:24
Thanks DP. I will check there first.appreciate the answer. DB
