Restoration & Repair Tips Board
56 Model 60 JD Carburation Problam
jerry-a
03-18-2008 07:35:07
the carburator has been rebuilt; the head reground; and plenty of spark with a good gas stream. But, although I get black smoke when turning the engine over and it "catches" and trying to start it will sputter and seems to be a minor adjustment away from running dependably. Any suggestions pertaining to adjustments? (it was a fast starter before the repairs were made).
steve l
03-21-2008 18:52:48
 Re: 56 Model 60 JD Carburation Problam in reply to jerry-a, 03-18-2008 07:35:07
The carb doesn"t like anything but gas any water est from rebuild could mess you up, drain carb and try again. Could the distributer have moved for timing or bumped and not tightened down. They will almost run when that happens.
old
03-18-2008 12:12:31
Turn on the gas, count to 60, turn off the gas. Try to start it up. If it fires up then turn on the gas and adjust it from there. Sounds like your load jet is open way to far or the main jet is wore badly. Or you could also have a float problem
