Restoration & Repair Tips Board
450c dozer oil return
Tomlbva
03-20-2008 06:38:57
we are having a problem with our 450c john deere dozer. We think the weep holes are stopped up because the oil will not return back to the transmission. It over fills the clutch housing and won"t return to the transmission case. Any help would be great.
jdemaris
03-20-2008 09:51:42
 Re: 450c dozer oil return in reply to Tomlbva, 03-20-2008 06:38:57
You kind of lost me - what weep holes? Steering-clutch housing is a separate oil-fill and not common with the transmission sump. When the housings overfill - it's because your clutch-pack is leaking and needs to be fixed.
Tomlbva
03-21-2008 05:34:38
 Re: 450c dozer oil return in reply to jdemaris, 03-20-2008 09:51:42
Thank you jdemaris for your quick reply. We found a blown out hose inside the clutch housing going to the clutch-pack.
We are hoping that when fixed it will salve our problem. thanks for your help.
