Restoration & Repair Tips Board
TL-12 rebuild info for AC WD-45G 226 CID
Don Nelson
03-21-2008 10:55:48
Looking for torque specs on Allis Chalmers 226 CID gas for mains, rods, head, valve rockers...
Also timing order, valve lash, point gap, plug gap...
Paul from MN
03-21-2008 12:24:20
 Re: TL-12 rebuild info for AC WD-45G 226 CID in reply to Don Nelson, 03-21-2008 10:55:48
Valve Lash .013
Plug Gap.028 and .032
Point Gap .020
Firing Order 1,2,4,3
Torque Head – 90 lbs. There are also three 3/8” studs which should be torqued to 25 lbs.
Rods – 70 lbs
Mains – 85 lbs
Don Nelson
03-21-2008 15:00:11
 Re: TL-12 rebuild info for AC WD-45G 226 CID in reply to Paul from MN, 03-21-2008 12:24:20
Thanks for the quick reply
JMS/.MN
03-21-2008 22:29:54
 Re: TL-12 rebuild info for AC WD-45G 226 CID in reply to Don Nelson, 03-21-2008 15:00:11
Any additional info you need on the WD45 ,226 engine, is in the I&T manual-AC 11.
