Restoration & Repair Tips Board
CASE S BRAKE DISCS
canadian northe
03-24-2008 10:57:43
DOES ANY ONE KNOW HOW TO REMOVE THE INNER BRAKE DISC ON THE CASE S /THERE DOESNT APPEAR TO BE ANY PLACE TO APPLY A PULLER.THANKS IN ADVANCE.
patsdeere
03-24-2008 14:15:33
 Re: CASE S BRAKE DISCS in reply to canadian northerner, 03-24-2008 10:57:43
I don't know how much help this will be but, I will put it out there anyway.
Are you referring to the one that actually goes inside the case on one side and gets the disc pressed against it on the other side? Mine were loose and leaking oil, so I wouldn't have had much problem getting them out. You do have to remove the brake cover studs before trying to take it out since they hold it in.
FYI - POSTING IN CAPS ISN'T ALWAYS LOOKED UPON NICELY.
canadian northerner
03-24-2008 17:43:30
 Re: CASE S BRAKE DISCS in reply to patsdeere, 03-24-2008 14:15:33
The discs in question are the ones on the inside.I thought posting in caps would help us ole folks see the print better.For all those who were offended all i can say is in time you will understand what i mean.Thanks in advance.
