Grey fergie
robo
05-17-2002 07:30:19
I cannot engage the reverse gear or starter position with the gear stick - any suggestions would be much appreciated
H.T.Hertz
05-21-2002 14:52:22
 Re: grey fergie in reply to robo, 05-17-2002 07:30:19
Look and see if you haven't got the shifting fork sitting between neut and start or between neut and reverse, then it is blocked for the shifter ball.
Normally it is possible to pry the fork back in neutral using a good long screwdriver (not the vodka/juice type)
Good luck
Henning
