David Brown Tractor
Robby Harbuck
05-18-2002 12:05:30
I've found a David Brown 990 Tractor I'm considering buying. The Tractor runs good and the PTO works fine. The lift is not working, what is the worst case fix to this problem cost wise? Is this a large problem or is it an easy fix? Or should I not buy it at all. Thanks
Henning Thomssen
05-19-2002 10:41:54
 Re: David Brown Tractor in reply to Robby Harbuck, 05-18-2002 12:05:30
David Brown are good,strong,reliable tractors and easy to work on,once you get into them.I don't know about your Hydraulics problem,you should post this question in the Case/DB forum.Elmer over there knows these machines inside out.
