Hydraulic cylinder repair
John
05-19-2002 13:32:26
The hydraulic cylinder on my woodsplitter is leaking around the ram. I am attempting to tear down this cylinder but cannot get it apart. looking at the end of the cylinder that the ram comes out of, there is a recessed snap ring down in there. I took the snap ring out and am turning the seal housing counter-clockwise thinking that the end will un-screw. I have been using a dull chisel to turn the housing, however it does not seem to be loosening. I am judging by the distance it is from the snap ring groove. I have the housing pretty chewed up from using the chisel. the housing is too far recessed to get a pipe wrench or the like on it. Does anyone have any ideas on how I can get this apart?
Dave, Sherburne, NY
05-20-2002 19:08:53
 Re: Hydraulic cylinder repair in reply to John, 05-19-2002 13:32:26
sounds like the cylinders on my JD backhoe Did you get all of the snapring out? If you did , just pull on the yoke at the end of the rod and pull the shaft and seal out as one unit .
John
05-21-2002 04:05:02
 Re: Re: Hydraulic cylinder repair in reply to Dave, Sherburne, NY, 05-20-2002 19:08:53
Thanks Guys, I'll give that a try.
Jerry B
05-20-2002 08:23:10
Sounds like the seal housing is stuck in the cylinder bore.
Air pressure applied carefully will blow the housing out.
Be careful as this can be dangerous.
Jerry B
05-20-2002 08:23:53
John
05-20-2002 16:20:30
 Re: Re: Hydraulic cylinder repair in reply to Jerry B, 05-20-2002 08:23:53
are you saying that the housing isn't threaded and that the snap ring is the only thing holding the end of the cylinder on?
Jerry B
05-21-2002 08:30:46
 Re: Re: Re: Hydraulic cylinder repair in reply to John, 05-20-2002 16:20:30
If you are turning the packing inside the cylinder and the unit is not unthreading then the snap ring must be the only thing holding it together. (that and crud build-up at the end)
