Restoration & Repair Tips Board
New Zenith Carb Tuning - 9N
Brian (1941 9N)
04-09-2008 16:48:06
I just received a new Zenith Carb for my '41 9N and wanted to confirm the correct out-of-the-box tuning. Is anyone familiar with this carb. There are two adjustments not including the throttle screw. The first is a wing-type screw at the bottom of the bowl, which I suspect controls the flow to the main jet. The second is a screw going into the main body of the carb. This appears to be the fuel/mixture screw.
thanks,
Brian
Brian (1941 9N)
04-10-2008 12:29:01
 Re: New Zenith Carb Tuning - 9N in reply to Brian (1941 9N), 04-09-2008 16:48:06
I just spoke with Jeff from YT and he indicated that the setting should be 3/4 out for the fuel/air mixture screw, and 1.5 turns out for the main jet screw at the bottom .
I'll let folks know if the final adjustments differ.
Brian
