Restoration & Repair Tips Board
Hydraulic problem on International 2424 diesel tractor
Gary Kestler
04-13-2008 20:45:53
I purchased this tractor in Vegas and used it occasionally to level lots and such. I noticed the steering wheel started chattering and got worse to the point it does not steer nor does the three point hitch go up or down. I found a replacement hydraulic pump (new) on-line and switched it out on the right side of the motor near the front. The tractor worked fine for a while and then did the exact same thing. I have been told it sounds like the pump is starving for fluid. I have no idea where to look or where to start to fix this. This tractor ran great but now cannot be used at all due to the steering being 100% hydraulic. I would like to hear from someone that may have been through the same thing. Thanks Gary
Edpap
04-14-2008 11:27:01
 Re: Hydraulic problem on International 2424 diesel tractor in reply to Gary Kestler, 04-13-2008 20:45:53
Hello Gary,
There is a suction screen in the hyd reservoir. it will be right under your right leg when you siting in the seat. there should be a hose clamp. just pull the hose off and unscrew the fitting and the suction screen will come out with the filter.
Good luck Ed
