Boom on interational backhoe
Kerry Hollis
05-20-2002 08:38:01
I just purchased a 3444 Int. loader/backhoe, the swing was working when I loaded, but after getting it home the boom won't swing, the tractor leaks hy-oil pretty bad and I had left it running during transport and wondering if the engine driven pump operates power steering and boom swing? And if so and the pumps burnt up, where I could get replacement?
chad
08-07-2002 20:18:25
 Re: boom on interational backhoe in reply to Kerry Hollis, 05-20-2002 08:38:01
I have a 3414 IH loader/backhoe . The swing and steering do operate from the pump on the motor .There should be a diverter valve somewhere neer the seat . if you still have power steering your pump still works .try moving that valve when you try to swing . good luck
